06-18-2016 02:00 PM
I've got a quick question, and I guess I didn't find the right keywords, since I couldn't get my answer by googling it
Let's given that I have a typedefed enum, called ENUM_myenum, that has three values:
- Value_One
- Value_Two
- Value_Three
I can use the search tool (Ctrl + F) in order to find all instances of ENUM_myenum. Good.
But how can I search for all instances of ENUM_myenum of value Value_Two
Is this even possible ?
It gets annoying when taking over someone else's code
Thanks in advance
06-18-2016 02:21 PM
You can do a Ctrl-F Find search, but change the search type to Text and put Value_Two as the search object. Note that you can choose whether or not to ignore Case (capitalization) and a few other options. It will find not only the Enum value, of course, but also where you documented (you do document your VIs, don't you?) Value_Two ...
06-18-2016 02:45 PM
