11-16-2009 12:25 PM
My quick-drop list doesn't come up anymore when I press ctrl-space. When I initially press ctrl-space (after loading LabVIEW) my machine behaves like it is loading the drop list (LabVIEW lags, and my hard drive thrashes for about a minute), but no drop list appears. My computer is kinda slow and outdated (hense the long inital load times of the drop list) so that may be the issue. I'm running a 1.6GHz Centrino w/ 1.5GB of ram and Windows XP SP3.
I've tried rebooting. I was using the drop list quite a bit before it stopped working. I would like to avoid a full reinstall of LabVIEW over this.
Any advice?
Thanks!
-Nic
Solved! Go to Solution.
11-16-2009 12:27 PM - edited 11-16-2009 12:27 PM
11-16-2009 12:55 PM
I've tried restarting LabVIEW with no luck.
One thing i just discovered is the functionality of the Quick Drop list is working. I can press ctrl+space and type "add" and press enter and the add function appears. The drop-list window is not appearing on the screen.
-Nic
11-16-2009 01:11 PM
Just grasping at straws but...
In the LV .INI file there is a line
"QuickDropPosition="
That apperas to save where the QD window waas when last used. Maybe yours is set for an off-screen position.
Ben
11-16-2009 02:08 PM
11-16-2009 02:39 PM
Ben,
Did I ever tell you that you're my hero?
11-16-2009 07:12 PM
Nickerbocker wrote:Ben,
No. He is the HERO (common to all)
