I use the example queue state machine + event structure + boolean switch, the examples which I have seen used boolean switches which latch when press and when the program read the switch status; the switch goes back to the initial state (False).
in my application, I would like to have the switches behave like a light switch, turn on and stay on until the user turn off and stay off. I don't want the program to read and reset the switch.
When I change the mechanical action of the switches, the example Queuestatemachine.vi behaves differently (or does not work properyly)
My question: what do I need to modify to get the switches behave as light switches?
