06-23-2012 10:59 AM
Hi All,
I am trying to track down a bug in my code to no avail (so far). I wanted to check if my problem is caused by a 'feature' in LabVIEW while I continue to tear (whats left of) my hair out.....
Here is what I'm doing:
If anyone can offer suggestions that I can check or indeed if this is a 'feature' which has come up before I'd appreciate any comments,
Dave
Solved! Go to Solution.
06-23-2012 11:34 AM
Hi All,
Please disregard the comments about the reference hex numbers being different - I built a very simple test program to make sure performance was correct and found that it was. In my test code both reference numbers are identical as should be expected! Its a common/garden bug causing my problem not a LabVIEW 'feature'......just gotta find the bugspray now!
Dave
06-23-2012 11:50 AM
Got it....I generated a second queue reference and over-wrote the original - this updated the DVR but not the state-machine queue. Rookie mistake - doh!
