08-23-2013 10:03 AM
Quick question about LabVIEW's Quadratic Programming VI (since the help for this particular VI is woefully unhelpful). If I use the inequality constraint cluster, am I obligated to use both Imin and Imax?
Right now I'm getting the {-20068: qpopt - equality constr main loop} error, but the equality constraint input is not connected to anything. I am using the inequality constraint input, with D having size [m x n], Imin having size [0] and Imax having size [m]. Is having Imin and Imax sizes unequal a problem? If so, what if I only have bounds in one direction? The way that I've usually seen the inequality constraints formatted (and what Matlab's quadprog uses) is:
Ax <= b
where as LabVIEW formats the inequality constraints as:
Imin < Dx < Imax
How can the two be reconciled?
08-26-2013 11:16 AM
Hi Keith,
If you don’t set up the constraints, they will have the default value of 0. I believe that you’ll need bounds in both directions, if not, one or the other could be set to 0, It’s important that the condition Imin < Dx < Imax is met.
Are you selecting also the correct instance of the VI? (IP or AS)
04-29-2014 02:50 PM
I have the same problem but I don't understand how to solve it. I have inequality conditions A and b but no Imin, D and Imax. I suppose A corresponds to D and Imax corresponds to b, but to what does Imin correspond? How can I plug in the condition Ax<=b into Labview quadprog?
Thanks!
