04-24-2013 08:02 AM
Hi again.
I'm glad that you have fixed the problem, however I really think you should consider your solution one more time and take a look at the state machine instead of using the Sequence Structure.
I found a pretty good forum post, that discusses State Machine vs Sequence Structure:
State Machine vs Sequence Structure for DAQ read/write and file I/O
04-24-2013 02:01 PM
Ah.. I see..
Thanks a lot for mentioning it.. I'll have a look at it, and see what it is 😃
04-25-2013 02:40 AM
I would love to check out the example, although i only have labview 11 and apparently can't open the file because it's made in 12 🙂
Thanks for mentioning state machines though.. It seems like a good idea
04-25-2013 02:57 AM
Here you go 🙂
