Pulse Train does not seem to run for the proper amount of time
I was hoping someone could assist with a pulse train I am trying to code.
I need to be able to trigger a relay to stay on for 500ms and stay off for 600000ms
My duty cycle for this is 500/600500, or .0008
That is all fine and well, but how do I actually have this work correctly?
My code is attached. What am I missing?
Attached is image of the code and also the VI
(2,237 Views)
you have no loop to let this code run, you start it then almost immediatly stop it.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,232 Views)
Right, yes, that's missing, but how do I ensure that it runs for the exact time I need it to? That is what I am not sure about.
How do i tie in the time component to this?
(2,229 Views)
I do not understand how I'm supposed to have the pulse stay high for the allotted amount of time and then stay off..
(2,226 Views)
Hi Belopsky,
You have already calculated your duty cycle, which is great. Next, you need to set your frequency, which is the inverse of time. Since the total pulse width (total time) is 600500 ms, or 600.5 s, your frequency is 1/600.5 which is approx 0.0017 Hz.  Since it doesn't divide evenly, it won't be exact, but it should be within tolerance if your low time is 10 minutes. Don't forget the loop too!
(2,175 Views)
