02-01-2015 09:41 AM
02-01-2015 12:04 PM
02-01-2015 09:11 PM
02-01-2015 09:18 PM
02-02-2015 01:45 PM
So I found a really simple way of generating a PRBS and outputing it on the digial output pins. I've attached a snapshot of the block diagram to do this.
However, the highest switching frequency I've been able to obtain through this method is 22.727 kHz.
I need to reach between 100k-200kHz.
Any suggestions on alternative methods or ways to improve this method?
Matt
02-02-2015 02:15 PM
I suspect the problem is that you are sending single points (as opposed to a PRBS, where S stands for "Sequence", i.e. a train of pseudo-random binary numbers) to the Express VI. You are probably seeing the overhead of trying to output "one point at a time", where the hardware wants to output at a much faster clock rate (on the order of 100KHz or better).
BS
