01-24-2014 07:22 AM
Hello all,
I´m new here and I have a problem.
As the subject already tells the property node: Interface Information: Interface Description fails on second call.
I have written a SubVI to get the virtual COM Port of a specified Device, which is connected via USB to my computer.
Therefore I use the "VISA Find Resource" VI to get a list of all active COM Ports and then use the mentioned property Node to get the device information.
I search for a specific string in this device information and if this string is found, I have my needed COM Port.
This is all working. Except for the case I start this SubVI a second time.
I always get an error from this property node saying: Error: -1073807246 in Property Node, VISA: (Hex 0xBFFF0072) The resource is valid, but VISA can not currently access it.
I don`t understand why I´m getting this error. I don`t even open the VISA Resource. I just check the name of it and make a VISA Close.
Maybe the problem is in my device?! I don`t know.
If I switch my device off and on again. My VI is again working once.
I hope someone has an idea, where this problem comes from and how to fix it.
I have the part of my SubVI, which is relevant to see the issue.
Thanks in advice
Best regards
TDO
01-24-2014 07:26 AM
01-24-2014 07:28 AM
Oh I`m sorry... I didn`t know, these two forums belong together
01-24-2014 07:36 AM
Hallo TDO,
die gehören nicht zusammen.
Trotzdem werden CrossPosts nicht gern gesehen, weder im LabVIEWForum noch hier - zumindest dann, wenn der OP nicht darauf hinweist. Hast du im LVF mal die Forumsregeln durchgelesen?
Gruß
01-29-2014 07:07 AM
02-07-2019 06:24 AM
I tried and I did not find why you receive this error.
I don't receive any error, I have got only 2 serial ports, one system port, the other from Arduino.
Ususally you receive this kind of error if another program or process take the possession of the resource, opening it.
Do you do something else after this code? Maybe you use your port, and forget to close it ?
