01-30-2017 06:28 PM
I am experiencing this error when I run your code, but not when I make my own version of the express VI. What objects on the Express Vi did you alter?
01-31-2017 07:48 AM
I set a variable called string to type text box and added a message and added a cancel button. I may have touched title too.
01-31-2017 07:52 AM
Yes, although I am very sure we had this same issue in LabVIEW 2009 32 bit
02-01-2017 03:33 PM
Ok, I got to play with it a bit more.
Try these steps:
1. Drop a Prompt User expess vi
2. Name an output "String" and set its type to Text entry box (Note the capital letter)
3. Press Ok
4. Double click the Prompt user express vi to edit
5. Press Ok without making changes (at this point i get the error)
02-01-2017 03:41 PM
I repeated the steps you've outlined and have the same error. LV 2015 32 bit on 64 bit Win10.
02-01-2017 03:55 PM
I see it in LV 2014 SP1 as well.
Providing information on how to replicate it helps a lot. It makes some sense that there is a problem with "String". I don't know what the underlying Express VI configuraiton code looks like, but I can certainly believe that "String" would be a reserved name. Probably the underlying code is using the label name as part of the property node that sets parameters for that control. If you try running a VI with that express VI after you've gotten the error on OK'ing the dialog, you'll see the dialog is messed up and is missing the text box.
If you really must have a value called "String", I see two fixes.
1. Add a space to the end of it. "String ".
2. Change it to some other name. Open the Express VI, a couple of times until OK doesn't cause an error. (It seems like a change in name to String happens the first time the Express dialog is configured AFTER it has been named. Open it up one more time and change it "String". You'll be okay as long as you don't open it up the again, otherwise you'll have to repeat this step.
02-02-2017 01:40 PM
Thank you nathanf and everyone else for bringing up this issue and testing it across multiple versions.
I have filed CAR 628247 for this issue.
