02-24-2015 10:16 AM
Thank you for posting that. I wasn't familiar with that VI.
02-24-2015 11:20 AM
This will change the z-order of a control in a non-running VI.
02-24-2015 04:41 PM
The function you want to do is in an HMI based software like Wonderware (WW) or RSView. You can simulate the same as a pop up window control as in WW or RS View by launching each control in its own VI. Then you can move the control easily and stack the controls. The last Vi to be selected will have focus and will be acted on. Use Vi sever to update the controls of each.I do this with my HMI developed from Labview.
02-24-2015 05:05 PM
Here's a way to fake it.
Make two identical meters. Postion one directly on top of the other. Put one at the back, one at the front. Put the gauge between them.
Toggle the visibility of the top meter to make it look like z-order is changing.
(Note: you have to send the same data to both meters.)
See attached code.
02-25-2015 02:59 AM
So much nicer! Cheers
12-05-2017 05:58 PM
Another option is using a tab control and have the overlapping controls on different tabs. Controls that should appear on all tabs can be created outside the tab control, then dragged onto the tab control so that they are in front of the tab control. The tab control can be set to transparent, so that it is not visible.
