03-19-2007 12:37 PM
03-19-2007 02:09 PM - edited 03-19-2007 02:09 PM
Message Edited by JLS on 03-19-2007 02:13 PM
03-19-2007 02:32 PM
12-07-2021 08:15 AM
Small update: The owning vi (front panel) must also be the frontmost panel:
12-07-2021 09:22 AM
I just happened upon the documentation for this property: https://zone.ni.com/reference/en-XX/help/371361R-01/lvprop/txt_selection/
If you set the start and end to be the same, LabVIEW inserts a caret into the text. If you want to highlight the text, you must set key focus on a control before you use the Selection property.
Which confuses me a bit. It talks about highlighting as something independent of selection. Is this true and if so, what are the consequences?
Also, am I correct in that "inserts a caret" does not actually insert anything into the text but should be taken to mean "sets the cursor to this position"?
12-07-2021 09:35 AM - edited 12-07-2021 09:36 AM
This is a bit a 3-fold function as far as I understand::
