07-18-2014 11:59 AM
I have an array containing list of physical channel controllers. I want to filter the physical channels based in user inputs. For Ex: If the user selects Device 1, the physical channels should only display channels connecting to device 1. Currently the phsical channel array just displays all physical channels available. Is there a way to filter physical channels based on the selected device.
07-18-2014 12:10 PM - edited 07-18-2014 12:10 PM
Use a FOR loop with a Search/Split String. The "offset of match" will be -1 if the item was not found. So use a conditional autoindexing tunnel to only include the items that were found (index >= 0).
07-18-2014 12:16 PM
I see that you have filtered out the channels based on Device selection, but I need the filetered out channels to be controllers, not indicators.
Users should be able to select custom channels from the filtered out list.
07-18-2014 12:26 PM
That's the hard way Tim
