12-19-2014 11:26 AM
I want to programmtically change the lower and upper limits of the X-axis on my Waveform Chart by using two numerical controls on my Front Panel.
I thought I could do that by usng the X Scale >> Range >> Maximum, and X Scale >> Range >> Minimum property nodes, but it does not work.
I am not too sure of the right property node to use in this case, and would appreciate any suggestion.
Thanks in advance.
12-19-2014 07:37 PM
Did you remember to turn off autoscaling? If not, it'll scale right back. Otherwise, you should have the correct property node.
12-22-2014 08:16 AM
Hi natasftw, thanks for your response. Yes, I did turn Auto-Scaling off.
12-22-2014 08:48 AM
