Programmatically changing the X-axis limits of a Chart
I want to programmtically change the lower and upper limits of the X-axis on my Waveform Chart by using two numerical controls on my Front Panel.
I thought I could do that by usng the X Scale >> Range >> Maximum, and X Scale >> Range >> Minimum property nodes, but it does not work.
I am not too sure of the right property node to use in this case, and would appreciate any suggestion.
Thanks in advance.
(3,280 Views)
Did you remember to turn off autoscaling?  If not, it'll scale right back.  Otherwise, you should have the correct property node.
(3,248 Views)
Hi natasftw, thanks for your response.  Yes, I did turn Auto-Scaling off.
(3,181 Views)
So, is the problem fixed? If not, you have to show your code.
(3,172 Views)
