12-15-2014 12:39 PM
Ok, so the idea is that I have a chart with two different data types on it. One is plotted on the primary Y-axis on the left side and the other is on the secondary Y-axis on the right side. Both share the same X-axis.
How do I change the range seperately for the primary Y-axis and secondary Y-axis? Whats currently happening is no matter which "Active Plot" or "Y-Axis Index" I select, it only changes the range for the secondary axis. Any help would be amazing!
12-15-2014 01:10 PM - edited 12-15-2014 01:16 PM
We are going to need to see some code to help with this. and some clarification sinc a "Chart" cannot have multiple y axes
Assuming you have an XY Graph this little code demonstrates how to set the scales min and max programatically
12-15-2014 01:28 PM
This is what I was looking for. For a few hours I was trying to do this with the properties "Active Plot" and "Y axis Index". Thanks to you I now know about "Active Y Scale"
12-16-2014 03:04 PM
I would not like to be boring here... but a chart CAN have multiple Y scales...
Right click on first scale >> duplicate scale
