10-24-2014 01:53 AM
Hi All,
I want to programmatically change icons of all the VIs in a LVLib, if I use the "Apply Icons to Existing VI items" method, i get a popup for saving the VIs,is there any way to programmatically avoid this popup or any other way in which I can apply the icons to all VIs of a LVLib.
Thanks and Regards,
Sree
10-24-2014 10:14 AM
You can use the invoke node for Save Instrument. Of course I am curious on why you would want to edit anything under the VI.lib. This is sorta like wanting to change Windows DLLs found under System32, it is generally a bad idea, that is unless you put the files there and know what you are doing.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
10-24-2014 10:22 AM
Read the original post a little closer. The OP wants to set the icons for a LVLIB they created. There is no mention of changing anything inside of vi.lib.
I personally just use the Apply To All Items. Then there is just the Save-All option on the save dialog.
10-24-2014 11:19 AM
Ahh yes my mistake. My brain saw LVLIB and thought it was vi.lib.
10-27-2014 11:51 PM
Thank You both for replying
I am using the "Apply Icons to Existing VI items" method now with the "Save All" pop up, another method which I tried is changing the Icons of all the VIs in LVLib and saving it individually which seems to work out but it is time consuming than the previous method.
Sree
