10-09-2014 09:02 AM
I want to connnect rows and columns of NI switch PXI2532B. I created a scan list as given below
/DEV1/R0->*****,
/DEV1/R2->*****,
/DEV1/R1->C21,
/DEV1/R3->C21
Iam able to do this with DAQMX switch connect.vi. Is there a way to cross check programatically through labview this row and columns are really connected before proceeding to next task?
Thanks in Advance
10-13-2014 03:31 PM
So the help on the Switch Connect (Multiple).vi states the following:
If you set wait for settling to TRUE, this VI waits only after making all connections.
So this function has an input that can force the VI to wait until all switches have been made. As for the single switch route. You can follow the Switch Connect (Single).vi up with the Switch Wait For Settling.vi.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
