Program which tab is visible
Hello community,
I feel like this is a trivial question though I couldn't find the answer searching the forums.
How do you control which tab is visible? I figured there would be a property node or something but maybe I missed it.
I've included an example:
I want the tab to change when I change the control. So when the control says "Scan Voltage", the "Scan Voltage" tab becomes active and if I change to "Scan Frequency", the "Scan Frequency" tab becomes active.
Vedran
Where awareness goes, energy flows.
(2,399 Views)
Accepted by topic author VedranJ
VedranJ wrote:
I feel like this is a trivial queston...
Use a local variable of the tab control.
GCentral
(2,386 Views)
Yes, thank you!
(2,376 Views)
