04-23-2015 08:05 AM
Hi
I am using producer/consumer architecture with an event structure. I am using queues. I would like to optimize my work with queues. At the begining my code looks like:
After the optimization my code is:
The application starts normally but I have to push a lot of times my buttons related with the optimized queues to launch the corresponding event. Before this optimization everything was OK. Could somebody help me?
Regards
04-23-2015 08:42 AM
That's way too much spagetti. I don't think many people will be interested in digging into that mess.
Since you have an earlier ('unoptimized') version in which "everythin was OK", just go back to that.
Other than that, my suggesttion would be to start over; this time without pasta.
04-23-2015 08:54 AM
I have to agree with Paul.
Looking at both of these images, it's hard to find the willingness to use the word "optimisation" at all.
You really need to clean things up, maybe then your problem will be much more apparent to you.
04-23-2015 09:17 AM
Yes you are right!
Therefore I would like to optimize my code. My first step was to optimize my queues. I have started with two of them (Microscope and PositioningStage). At this stage the other queues are not important.
Regards
04-23-2015 09:40 AM
04-23-2015 09:52 AM
@tiho wrote:
Yes you are right!
Regards
Your first step should be cleaning up your wires so that you can even see what is going on.
04-23-2015 11:05 AM
What do you mean here by "optimize"? What are you optimizing for - performance, usability, readability, something else?
04-23-2015 02:38 PM
I'm confused by your Block Diagram. You seem to have 4 Queues
04-23-2015 02:49 PM
I'm confused by your Block Diagram. You seem to have 4 Queues, and in the Event structure, you put something on each of them. That seems strange (but, then, I don't know what you are trying to do). I've (almost) never written a loop with multiple error lines coming in to it; either there is an Error when you enter the loop or there is not! If you want to do several things in parallel, each on its own Error line, you can branch the single Error In, and collect them with Merge Errors so that you have a single Error line going out. [If you are concerned that you won't know "who caused the error", the Error Message usually gives you a clue, and you can also put a Simple Error Handler inside, if you are nervous).
I also notice that your Queues seem to come out of the Enqueue loop. Why? The only reason I bring mine out is to immediately wire them to Release Queue (because if I exit the Enqueuing loop, I'm probably done with the Queue).
Someone else asked what you meant by "optimize". When I look at your two examples, it looks like the "optimized" Queue just has additional Stuff inside it. Care to explain?
P.S. -- I suggest about writing a short essay called "This is What I Want to Do -- are Queues Helpful in this Context?". If we know what you are trying to accomplish, I'm sure you can get helpful "design" suggestions.
04-24-2015 04:08 AM
Thank you for your answer. I
Yes, I have 4 queues. Each of them is related with a different hardware control device (camera, manipulator, microscope, positioning stage, image processing). I have corrected the error line and now I have a single error line going out from the loop (the screenshot below). My Queues come out of the enqueue loop because they wire to Release Queue. I have a lot of wires comming out of my queues. I would like to reduce them (queues lines). Therefore I think that I have to bundle them in a cluster.
