Problems write in I / O with VISA Serial (low speed of the program while recording)
Hi! I being monitored voltage Serial port speed 230000Baud / s. It is fast and accurate, but when I want to record this data to a file tmds, xls, txt, this is reduced the speed of the program and buffer overflows series, which reduces the rate  voltage monitoring information. I have tried on 2 PCs with four core processors . I think that this is not due to the PC.
Because of what it might be?
(2,388 Views)
Accepted by topic author Pachik
File IO is SLOW.  So you need to offset that somewhere.  Look at the Producer/Consumer.  The idea here is to have a loop that just reads the serial port (as fast as it needs to) and use a queue to pass the data to another loop for processing and saving it to disk.
GCentral
(2,382 Views)
Thank you! I like it helped.
(2,347 Views)
