05-09-2014 11:25 AM
Hi guys, I'm starting to work with Labview and also Arduino and I'm facing some problems. I created a program to make two LEDs blink in parallel using Arduino. This program worked fine, but now I want to make it a little bit more complex inserting a button to select which one of the LEDs will blink. I created a logic to do this but it's not possible to implement it due to the different kind of connections (digital, boolean, string). I would like to know if someone can help me with this. I'm posting the VI. Note that I left the logic that I created in the VI, so you can see what I thought to do. Thank you!
*Ps: I don't know why I'm not able to post my VI. When I try to post with it attached I receive the following message: "The contents of the attachment doesn't match its file type.". So i'm posting one picture of the circuit. =/
05-09-2014 11:41 AM
What options are you looking for? Both blink, neither blink, LED1 only blinks, LED2 only blinks?
As far as not able to post a VI, we've had that issue for awhile. I just zip up any VIs I need to post and post the zip file. Snippets also work well.
05-09-2014 11:53 AM
Hello, thanks for the fast response. I tried to attach using winrar, but this was not an valid extension. Now I did with Winzip.
What I really whant is only one LED blinking per time. One or the other. Can you help me with it?
Ps: The zip file didn't work also! =(
05-09-2014 12:34 PM
I added it to my Dropbox, so now it's possible to download the VI from there.
05-09-2014 02:01 PM
The logic using the "and" of the bottom was wrong. This one should be the right:
