Problems to create a basic LED program
Hi guys, I'm starting to work with Labview and also Arduino and I'm facing some problems. I created a program to make two LEDs blink in parallel using Arduino. This program worked fine, but now I want to make it a little bit more complex inserting a button to select which one of the LEDs will blink. I created a logic to do this but it's not possible to implement it due to the different kind of connections (digital, boolean, string). I would like to know if someone can help me with this. I'm posting the VI. Note that I left the logic that I created in the VI, so you can see what I thought to do. Thank you!
*Ps: I don't know why I'm not able to post my VI. When I try to post with it attached I receive the following message: "The contents of the attachment doesn't match its file type.". So i'm posting one picture of the circuit. =/
(2,423 Views)
What options are you looking for?  Both blink, neither blink, LED1 only blinks, LED2 only blinks?
As far as not able to post a VI, we've had that issue for awhile.  I just zip up any VIs I need to post and post the zip file.  Snippets also work well.
GCentral
(2,418 Views)
Hello, thanks for the fast response. I tried to attach using winrar, but this was not an valid extension. Now I did with Winzip.
What I really whant is only one LED blinking per time. One or the other. Can you help me with it?
Ps: The zip file didn't work also! =(
(2,413 Views)
I added it to my Dropbox, so now it's possible to download the VI from there.
(2,403 Views)
The logic using the "and" of the bottom was wrong. This one should be the right:
(2,388 Views)
