09-19-2013 12:23 PM
Hello I'm starting a robotics team where I work, high school so I hope my question isn't to rudimentary for this forum. I built the basic tetrix base but can't get the programming started. The robot essentially runs off of a lego mindstorms NXT module. When I try to test the sensors, or motors, nothing works, I can't even tell if they are showing up or not. I see them but can't tell if they're active. When I try to use the the schematic editor to test everything nothing seems to work. I can change the parameters, eg. motor direction, but it doesn't seem to affect the sensors, or motors plugged into the NXT. When I wave my hand in front of the ultrasonic sensor nothing changes, when I push the plunger on the touch sensor the values on the schematic editor don't change. I don't know if this has anything to do with it but I keep changing batteries but the battery indicator keeps showing the same level of power, almost dead.
09-19-2013 01:09 PM
If you post this in the Lego Mindstorms board you may get a faster reply. http://forums.ni.com/t5/LabVIEW-for-LEGO-MINDSTORMS-and/bd-p/460
09-19-2013 01:38 PM
Thank you, I just discovered the new forum and posted it there.
10-25-2013 02:51 AM
This article is intended to control the direction and speed of a Lego NXT robot using the directional buttons on the computer keyboard, strategic control distance limited by the scope of the Bluetooth transmitter installed.
https://decibel.ni.com/content/docs/DOC-32462
10-25-2013 02:52 AM
This article is intended to indicate the installation and configuration process between LabVIEW and educational robot Lego Mindstorms NXT wirelessly, this will enable LabVIEW developers in having a mobile platform for the development of projects and autonomous robots, we need to install some programs the computer:
10-25-2013 02:53 AM
This article is intended to carry out a program to monitor the status and speed of a motor connected to the NXT Intelligent Brick MindStorm from the front panel on the computer
10-25-2013 02:54 AM
This article aims to make a program that performs the reading of a sensor connected to the NXT Intelligent Brick MindStorm, display a message on the LCD screen of the device while on the front panel of our program:
https://decibel.ni.com/content/docs/DOC-32449
10-25-2013 02:54 AM
This article is intended to record the activity of the buttons on the NXT Intelligent Brick MindStorm, while pressing a particular button will produce a musical tone while a LED lights in the program.
