12-14-2016 06:44 AM
Hello everyone,
I'm using the book graphical programming with labview and I am having a problem. I (think) I did the same as in the book. However, mine keeps saying that I am trying to connect two arrays with different dimensions. When I change the empty array constant attached to the for loop the program will run but it will not be the result it should be.
I included the labview vi. I'm hoping someone can help me out.
Bart
12-14-2016 06:51 AM
12-14-2016 06:56 AM
Excuse me, I see I've send the wrong vi.
I've been stuck on this for a while now but I finally fixed it, I did not check concatenate inputs at built array. So I solved it, thanks for the help anyway.
