07-03-2006 08:48 AM
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
07-03-2006 02:15 PM
07-04-2006 04:23 AM
In some versions of Oracle, or with certain ODBC providers, the Microsoft ADO client cannot retrieve the properties requested by the Connection Get Properties VI.
Fortunately, most other commands and requests will execute without problem, and the only property that DB Tools Create Parameterized Query uses is the command timeout limit (as is explained in the block diagram). You can very easily modify the block diagram to specify its own timeout that is appropriate for your application. Save the VI with a new name and you will be able to use it in place of the original VI.
Check, that you have the latest version of Microsoft ADO, and Oracle's ODBC provider, .
http://zone.ni.com/devzone/conceptd.nsf/webmain/fa0a99e9bd96c8e98625713d007167ec
http://forums.ni.com/ni/board/message?board.id=170&message.id=71939&requireLogin=False
Christophe S.
07-04-2006 01:08 PM
08-04-2008 09:51 PM
08-05-2008 03:27 AM
Hi Tin
Unfortunately, I did not find any solution.
Regards
Simbani
08-05-2008 03:48 PM
08-06-2008 03:48 AM
Karunya,
I am using Oracle ODBC
Simbani
08-07-2008 07:09 PM
