06-06-2007 08:51 AM
06-07-2007 10:10 AM
Hi Lutz,
It is good to hear that the FGEN Soft Front panel is working, as this means the drivers and 5412 are properly installed and working. Is there a specific example program you are using which gives these errors? When do the errors occur? (I’m assuming immediately when the program starts – correct?) I would also like to ask for you to post screenshots of these errors, as this will allow me to see the error in its entirety, including error numbers.
Do you have a PCI or PXI 5412? If PXI, are you using MXI or have an embedded controller? If you have any other FGENs to test with (5412 or otherwise), and do they give the same results?
01-14-2010 11:32 AM
I would have liked to be able to see the resolution of the issue (perhaps it became obvious) - I'm experiencing the exact same problem. I have a VI that works fine on one computer (if it is relevant, running Labview 8.5) and when I copy the VI to another computer (with Labview 8.6) and install the NI-FGEN drivers there, I get the error when I first load the VI. Any thoughts?
- Joe
03-22-2012 02:50 AM
I encountered the same problem as you.
Does anybody know how to fixed it ???
01-10-2014 09:02 AM
Did anyone figure out what the issue was? I am encountering the same problem.
01-13-2014 09:16 AM
Anyone?
Or should is this post too old?
01-14-2014 11:59 AM
Bump
12-23-2015 02:59 PM
