09-19-2012 04:07 AM
When I use the Report Generation Toolkit (LabVIEW 2010), and Office 2010, the tables generated are bad.
In office 2007 in the tables are correct.
Someone can help me solve this problem?
09-19-2012 04:58 AM
Hi Jbatista,
there aren't compatibility problems between RGT (labVIEW 2010) and Office 2010, as you can see at this link: http://digital.ni.com/public.nsf/allkb/C9408B9F08D711E786256F3300701D01?OpenDocument
Maybe there were some installation problems when you passed from Office 2007, to Office 2010, so you can try to install Office 2010 before installing the Report Generation Toolkit and see if it works properly.
Bye
09-19-2012 12:29 PM
There's a known bug and work around.
http://digital.ni.com/public.nsf/allkb/4041ECB5D02BA57D862579A00002FE8D
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
10-16-2012 10:25 PM
The solution referenced in your post does not actually workas far as I can tell... at least for LV2011 and Office2010 on Win7
Am I missing something here?
10-16-2012 10:31 PM
Using the LV 2011 version of the Append Table to Report VI does not work either it seems...
10-17-2012 07:37 AM
There is some other bugs for sure when dealing with column and row headers. I believe if you don't have column or row headers the NI work around works. I had to have column headers and ended up modifying NIs fix to try to get it to work with some success.
