Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
05-05-2014 01:38 AM
hi
my front panel has two buttons and I have set different colors for ON color property (green and yellow). However,
when a button is pressed, it is highlighted in color set for the other button.
05-05-2014 03:13 AM
Any suggestion.....
05-05-2014 03:16 AM - edited 05-05-2014 03:17 AM
Hi Nustian,
at first: it is considered "rude" to bump a thread after less than 2 hours. We are just volunteers (atleast most of us)…
Second: you should attach a VI or atleast snippets to demonstrate your problem.
How should we know what you have set your buttons, how did you set their properties and what went wrong this way?
05-05-2014 05:00 AM
at first: it is considered "rude" to bump a thread after less than 2 hours. We are just volunteers (atleast most of us)… Noted
I am simply setting the color property through property pages, the colors are not set programmatically
05-05-2014 05:43 AM - edited 05-05-2014 05:43 AM
Why don't you exchange the buttons, when the colors appear on the wrong button? 😉
What happens when you redefine the colors for each button?
Thanks!
We'll be in touch soon!
