02-24-2015 11:53 AM
Hello Rick,
I believe I have found that the issue is about the cursor mode being used. I have uploaded your VI with the addition of a cursor mode control. You will see that the VI functions as expected for cursor modes 0 (free) and 1 (single plot) but does the same flicker you are experiencing for cursor mode 2 (multi-plot). I will investigate further into why this is but for the meantime, I would recommend setting a cursor mode of 0 or 1 to solve the issue.
Thanks!
02-24-2015 01:00 PM
Thank you Collin,
The reason I want to use the Multi-plot option is to read all values. I am interested to see where this goes. Thank you for looking into it. I will look at the VI you sent.
Rick
03-11-2015 12:16 PM
Hey Collin,
The problem seems to resolve itself by changing from mode 2 to 1. Is this just an issue with the MS graph?
03-12-2015 05:44 PM
Hello Speaks,
Indeed, the issue seems to be related to the Mixed Signal Graph. A Corrective Action Request may be filed to investigate the issue. In the mean-time, using a cursor mode of 0 or 1 should be an adequate work-around.
j_bou
