Let me explain a little the problem, this program works good when using in an flat sequence structure divided in 4 parts and in the third part there is a while loop. I was going to change it to set everything but the start camera and the parameters outside a while loop as i did with others drivers, however when using that, the first call library function node just liberates two numbers, zero and later 1 and it can not be changed those parameters. So, the only easy way to make it work was in this flat sequence but i am not that confortable, always that i use stop i have to close the labview and open it again because it does not work well when i stop and i try to initialize it again.
The second problem are suggestions just to change the While Loop in the third block of the flat sequence structure, i was thinking that that possibility could work well, but i tried changing it by others structures and is not working well.
Thanks for any help you can give me
