05-05-2014 06:50 AM
I am implementing the program recording and processing of EMG signal. The program has two parts are Aquisition and Processing.
+ Aquisition: recording EMG signals continuously using electrodes sensor to EMG circuit transmit to PC through the COM port and display to Graph Chart.
+ Processing: allows to make a number of signal processing such as filter, spectrum analysis, ...
Parameters:
Sampling - 16ksps, ADC24bit, USB interface,...
The data collection is perfectly good. However I have a problem when adding the frequency component into signal using the "Build Waveform", the signal waveform is plot very slowly almost not meet. I do not know how to process it. I need a solution.
Help me.
Thanks.
05-05-2014 07:26 AM
05-05-2014 10:07 AM
Thanks for reply.
I think the problem here is the plot 1D array of integer data type, the data is plot continuously and easily. When I use build waveform, data signal is converted to Dynamic signal and plot to Waveform Chart. That make plot data very slowly and not be. Data were read-time continuous recording from the COM port.
