07-20-2017 07:57 AM
Hi!
I found an interesting example: "Simulating a wind turbine"
But when I tried to open it I can´t because I dont have LabVIEW Control Design Toolkit
I downloaded the evaluate version and installed it following the instructions but after that procces, when I try to open the program it doesnt find Sim halt.vi
How can I solve this? Shall I dowload another toolkit for this example or what is wrong in my computer?
Thanks for your help
07-20-2017 08:43 AM
Did you search the forum? Have a look here.
07-20-2017 12:32 PM
Yes men, but it doesnt solve my problem
07-21-2017 03:54 AM
Attach the example here of "Simulating a wind turbine" and I will try to open it. I have Control and Simulation design module 2016. If it works, then you would know what it needs.
07-21-2017 04:29 AM
Thanks for your response CataM, I have attached you the example
07-21-2017 04:38 AM
No problem opening it.
I have this module: http://www.ni.com/download/labview-control-design-and-simulation-module-2016/6160/en/
07-21-2017 05:07 AM
Hi again
Thanks for your time Cata, I'll probe with the link that you send me, but I think I have it installed, I have attached an image of NI license manager in which you can see that Control and design toolkit appears
07-21-2017 05:18 AM
Do you have Control and Simulation desgin module 2017 ? If so, then you nedd some other software because you already have the latest version. It works with 2016 module as well because that is the version I have.
07-24-2017 01:58 AM
I found the solution.
If someone have the same error, after installing the Control and Simulation desgin module 2017 I was trying to open the example with Labview 2017 64 bits version and it said that I haven't installed the toolkit but If you probe 32 bits version it works properly.
04-12-2018 09:24 AM
I have already LabVIEW 32-bit version and control design module 2017, but I'm still getting Sim halt.vi error.
and also when I open my QNET quick start program by ignoring the error it says that your control module is not installed
