Your screenshot verifies that we have the exact same IE 6 version (just for clarity, I attached a screenshot of my About box, where I only modified it by removing the Product ID for security purposes), which perhaps makes the solution a bit more subtle. Now the task is to figure out what relevant object differs on your machine from mine. The relevant objects we currently know about are the files which the installer looks for:
comctl32.dll
shlwapi.dll
oleacc.dll
But the noted entry points, respectively, are also important:
InitCommonControlsEx
PathIsUNC
CreateStdAccessibleObject
It is possible that although you have those dlls, perhaps the version of one or more is different from what I have, and doesn't contain the required entry point. I have the following versions for those files respectively:
5.82.2900.2180
6.0.2900.2781
4.2.5406.0
If you find those files under C:\WINDOWS\SYSTEM32 again, you can right-click on them to select "Properties" and then click the "Version" tab to get the version of each file. If you can post the file versions here then we can compare. If a file version is different, we'll have a potential solution in replacing it with the version I have.
Ok, I am sorry you are seeing this problem, and hope that we'll find the solution soon!
Best regards and I look forward to your repost!
JLS
