Problem in performing loopback test between analog output and analog input channels of same device
Hello everybody,
                           I am using PCI-6221 (37) module, and i would like to conduct loopback test on this module by looping back analog output channael to a analog input. By doing the code I am able to generate a DC voltage at Ao0 and measure the same at Ai0. But if I am generating a waveform at Ao0 channel and trying to measure same at Ai0 its nothappening, I don't know where is the problem. I f any one of you have done this exercise before kindly let me know.
I tried to generate a sine waveform of 50 Hz freq and 3 V amplitude at 1000 Hz as sampling rate and analog input side i setted the sampling rate as 3000 Hz
Thanks and Regards
Visu
(2,286 Views)
I suppose it will interest you to do diagnostic testing
Message Edited by muks on 09-18-2009 03:51 PM
(2,278 Views)
