01-07-2015 01:27 AM
Hello.
I am trying to use a network published share variable in labview real time on cRIO 9012.
I can view the variable in NI Distributed System Manager and control the variable through it but when I try to control the variable in the host VI, ie, a VI in My Computer and not the real time target(cRIO), it cannot be done.
The change in its value is being seen on the host VI but not on the real time target
The reference type of the variable I slected is absolute.
Awaiting a solution.
Thanks.
02-01-2015 09:26 PM
02-01-2015 10:03 PM
The variable is created in cRIO. But is controlled using a VI hosted on PC. Am I wrong in doing so?
02-01-2015 11:49 PM
02-03-2015 06:04 AM - edited 02-03-2015 06:05 AM
Read this Shared Variable Applications
...and check your <rt_exe>.aliases file. If your Shared Variable Engine (SVE) resides on the PC, it's IP should be saved here.
For debug disable your local firewall.
Hope it helps
Christian
