08-07-2015 12:44 PM
Hi
As you can see in the attahced image, I attempt to write a set of 2*202 data in each iteration of the loop of the loop, yet when I try to read the data (in the second picture) I only get the first (or last, I assume) set of data, up to index 202. I needed to read two set (X, Y) of 402 valuse. So, I am not sure if I am making a mistake in wrting to the file or reading from it!
I really appreciate it if someone could suggest a solution 🙂
Ashakn
08-07-2015 01:05 PM
You are only reading the first. In your read, set your number to read to -1. That will tell the Read Binary File to read all of the data instead just a single set.
08-24-2015 07:33 AM
Hey crossrulz 🙂
Sorry for my delayed response, I was on a vacation during the last two weeks.
Thanks for your reply. I tried your suggestion, it changed the look of data set in front panel, still I don't have access to the second set of data.
I have attached the result in a jpg file. Also, you can find the binary file (it should have 4 sets of data since I ran the code two times) and a CheckData.vi file in the attachment, I really appreciate it if you could take a look into the files.
Thank a lot 🙂
08-24-2015 08:43 AM
Your file only has 1 set of data in it. But looking at the code for writing the file, I think your error is with the setting of the file position. The default position is the beginning of the file, which means you will just be overwriting whatever data you have in the file. You need to tell it to set to the End of the file by setting the "From" input to "End".
08-24-2015 02:12 PM
You are right!...It's funny, somehow I have used the "set file postion" vi but forgot to set the position. Thanks 🙂
08-24-2015 02:26 PM
I don't see any thanks...(give this a read: Unofficial Forum Rules, especially the park on "giving thanks").
08-24-2015 04:15 PM
I didn't know the rules 😄 Thank you again.
