I am trying to install LabView ver. 8.5 for the first time. The installation procedure is telling me to put in the disk labeled National Instruments Device Drivers - August 2008 Disk 2. However I do not have a disk with that name.
I have 4 DVDs, three are labeled NI Developers Suite (disks 1-3) and the other is labeled NI Device Drivers Third Quarter 2008. However, that disk doesn't make the install process happy. How can I fix this??
You're not the first to run into this. If you insert DVD 4 you can point the installer to the directory named "DCD-Aug08-2" and it should be happy. It'll almost definitely ask for additional driver discs, but they'll be on DVD 4 every time.
