Hello, I am currently in training course, and I work on a project of realization
of remote TP. With this intention I have has my Labview provision and Fieldpoint. In order to order the assembly, I use a FP-AO-210. I manage well to send a
simple tension, the problem is located at the time of the transmission of a
sinusoidal signal. the error obtains following on Labview: Error -33180 occurred with the quantity
of provided data does not correspond to the number of elements of data required
or to the number of ways to be addressed: FP Write.vi
What I want to do, initially, it is to send, of labview, a sinusoidal signal and
to be able visualized on an oscilloscope. I use the sinusoidal foncion Waveform which makes it possible to create a
sinusoidal signal then I it sending on Chanel 0 of the filedpoint on the module
FP-AO-210 which makes it possible to send tensions between 0 and 10V.
will have wanted to know if the FP-AO-210 makes it possible to send a
aletrnatif siganl? So yes which are the tools under labview to be used? Has to
you it so not there an allowing module sends it a signal?
Thank
