12-05-2012 09:44 AM - edited 12-05-2012 09:45 AM
i want to print the FP of a VI multiple times and generate a PDF document.
Before:
i have used the following options.
VI Properties >> Print Options >> Print with Execution => this creates 3 pdf documents (on printing 3 times) instead of one.
VI Properties >> Print Options >> Scale printed front panel to fit page. => this option scales the FP to fit the page.
with these options the FP image really fits on the page.
Now:
i need a single PDF document with all the 3 pages.
Problem: If i use Append image to report VI, then i cannot scale the image on the page.
by saving the image to disk and then appending it to a standard report, the Image is not really fitted with the page in the PDF.
Please help
thanks
Renn
12-06-2012 03:26 AM
Even i had this problem when i built the Executable 😞 its really horrible.
http://digital.ni.com/public.nsf/allkb/8A0E6274D9BD7B1986256F62006AD402
i would like to buy NI Report Generation toolkit if i can avoid all these problems. can anyone please give your experiences with this toolkit and your suggestions?
12-06-2012 10:07 AM
Is there any other option?
with functionality of 'Scale printed frontpanel to fit page' ?
12-10-2012 04:42 AM
Print.Panel To Printer method of a VI prints the Frontpanel everytime it executes.
good : i can select the text (in any graph or cluster in a printed PDF) using mouse.
bad : i cannot decide when to print. (eg. if i want to create a multipage report).
But if i manually print a Front panel image, the quality is not so good.
i dont find a better solution in LabVIEW. 😞
12-10-2012 03:55 PM
i'm attaching an example vi which uses the method 'Print. Panel To Printer' and the created pdf. see page3.pdf. The quality of the pdf is really good.
PanelPrint.vi prints a page each time it executes. i need a single pdf (or single print job) with multiple pages.
but if i am using the report generation VIs, i am appending images to report and not getting the desired quality.
any suggestions??
CallerVI_Lv9.vi
PanelPrint.vi
