Steve,
Under the vi setup (right click icon from front panel)-> execution options
there is a
checkbox for 'print panel after execution', select this to print your vi
panel. you can develop a duplicate of your graph vi, select the print option,
and make background, etc. white to save on toner. you can then either call
this from your original vi, or add a 'print' boolean selection to let the
user choose.
pat
Steve Drake wrote:
>Hello again.>>I have a VI that is used to read a data file and plot it on
the>screen. Is it possible to take that chart even better the whole>VI and
print it to a printer. I found a VI that looked like it would>do that but
it keeps telling me the VI isn't in memory so I'm thinking>you can't use
that
VI to print the VI it's in, I think but I'm still>playing with it.>>
Also if you can print it can you change the plot so it has a black>line
on a white background, otherwise we could use up alot of toner.>>Thanks for
any help.>>Regards,>>Steve Drake
