03-16-2012 07:43 AM
Im trying to print an image(JPEG) from a given Path by the user, I want to generate an output log file that contains (Start of printing job,size of print data ,error's if any and print time,..) Which function can do that?
03-16-2012 07:53 AM
You can use Windows API function to control 'print function' and write small code to log all details.
04-16-2012 12:23 PM
Is ther any Tutorial about how to Use or editing in this Program?
thanks for your help 🙂
04-17-2012 10:43 AM
121312,
Are you asking about LabVIEW I'd recommend looking at the manuals if you are new to LabVIEW programming.
http://www.ni.com/gettingstarted/labviewbasics/
04-18-2012 04:17 AM - edited 04-18-2012 04:27 AM
I'm asking about the same Topic(printing improvement),I don't know how to use the windows API Function.
I have attached My code(get a specific picture from the user and it print it with the default printer with recording Estimated print time ,ink thickness and if there is any error a led should light up).
I have some problems,
first,when I try to do "a paper jam or no paper" in the Printer tray the Led should light up,but it don't
also the second prompt that come up i want it to wait for the printer to print first job then it pop up("Insert The paper Manually in the printer tray If you wish to continue")
another Is there a way Labview can open another program within my code (like opening a program called "IrfanView" to view & edit the picture)
Last, I want to record every single step at a report like if there is an error with a paper jam,size of print data..etc. And save it like a log file, I should do it manually like you can see it at the code or there is a better way?
04-22-2012 03:11 PM
Sorry,but no one can help me with this?
