04-11-2017 02:41 AM
I am trying to get the values from the accelerometer vi to be input to the FPGA module vi. However it seems that Labview doesn't allow both vis to be run at the same time together.
I also tried implementing the Accelerometer within the FPGA itself but it prompts that the personality does not allow it to be run.
Can anyone provide any insights on this?
04-11-2017 03:02 AM - edited 04-11-2017 03:02 AM
Hi doe,
Sure - as soon as you provide information on this:
Which VIs are you talking about? (Which LabVIEW version? Which target?)
04-11-2017 03:12 AM
I am using the Accelerometer vi of the myRIO
http://zone.ni.com/reference/en-XX/help/373925A-01/myrioreference/myrioref_accelerometer/
04-11-2017 03:22 AM
04-11-2017 03:25 AM
I tried implementing the Accelerometer within the FPGA but they said that the personality doesn't fit? Not too sure what does that mean.
04-11-2017 04:24 AM
Hi doe,
This means the ExpressVI isn't supported by the FPGA.
Is there anybody forcing you to stick with this ExpressVI? Can't you create your own VIs?
04-11-2017 04:26 AM
Oh sorry. I finally get what you mean. I will try to create my own VIs and see if it works. Thanks for the advice.
