Positioning panel origin inside the panel, not postioning panel on screen
Is there a run-time property for the form/panel that you can use to control the origin of the panel.  When I say origin, I am referring to the 0,0 coordinates used in the LEFT and TOP offsets used by the controls.  I found the FP.PanelBounds and FP.WindowBounds under the VI Server>VI>VI class.  However, this only moves the panel relative to the monitor.  I want to be able to move the panel visible portion relative to the form.  Exactly like the scroll bars do to the panel.  When using the scroll bars, I cannot accurately line up the origin in the upper left corner which throws off my form.  I am using this to develop a GUI on a 800x600 display, so the slightest offset is noticeable.  I have included an image to help explain.
(1,869 Views)
Accepted by topic author dedelmann
You have to implement something like this:
Norbert
Note that this code leaks references and does not work properly when using more than a single pane.
Norbert
Expert: Geometry
(1,864 Views)
