12-03-2009 12:39 PM
Greeting,
I am a new labView user (actually in class right now) and I will be maintaining previously developed code where the VIs run under TestStand. In one VI the user is instructed to check a certain LED. We would like to have an annotated picture pop up showing the user the location of the LED. This does not appear to be a Basics I or II topic so I would appreciate some suggestions. If a pop up is not possible then perhaps I could display it on a large front panel.
jh
12-03-2009 01:07 PM
You could adopt the strategy of being able to show lots of puctures when you need them. Put a pict ring control on the front panel...then show and hide it as need be selecting which image using a property node in code......you might try to use the text and pict ring too. Add the picts with cut a paste (havn't used it but that is what the help says.)....Perhaps someone could help us with a better description.
Hope that helps.
Hummer1
12-03-2009 01:34 PM
TestStand has a Message Popup step type and one of the options is to display an image or web page. No reason to write any special code.
What version of TestStand are you using? If it's an older version that does not have this option, I have a custom LabVIEW popup that does almost the same thing. It allows you to reference a bmp, png, or jpg file. I used files so that if the images changed, I did not have to modify the VI.
12-03-2009 01:47 PM
12-03-2009 01:54 PM
12-03-2009 02:05 PM
12-03-2009 02:11 PM
12-03-2009 02:31 PM
Thanks. Will give it a shot when I get back to VA.
jh
