02-11-2016 12:22 AM
I'm using labview 2013 now because i used it for some other project.
now i have a trouble...
For this project i'm using RIGOL DM3061 but i can't find the instrument driver. instead of it i found DM 3k series driver. ex) DM 3051, DM3058, DM3058E, DM3068
i tried to reset the divece and measure AC voltage several times.
Fortunately, I realise how to reset the device through the labview and set the mode to AC voltage measurement but after change mode it doesn't work at all
Does anyone know how to measure the AC Voltage using labview and RIGOL DM3061?....
Here is my program based on DM 3k series driver
This is the error report
Instrument reports:
-113,"Undefined header; keyword cannot be found"
0,"No error"
RIGOL DM3058.lvlib:Error Query.vi
RIGOL DM3058.lvlib:Configure Measurement.vi
EIT system read.vi
Help me...
02-11-2016 01:58 AM
Hi bermichse,
Instrument reports: -113,"Undefined header; keyword cannot be found"
Read the (programming) manual of your device. It explains each command and their (valid) options. (Cross-)Check each command you send to the device…
