Good Day, I am plotting a semilog graph displayed on the front panel of my program. The unit on the x-axis is in frequency(Hz) and the y-axis is in dBc/Hz I wanted to program in such a way that the a straight line is plot between points at 10,100,1K,10K and 100KHz.That is to say I only need to key in 5 values. My plot now jumps back to zero as all the values set to zero by default when i do not enter value into each array cell. I hope someone out there has solution to this. Thank you. Regards, Daniel
