04-03-2015 01:44 AM
I am getting 1D signal from a sensor which I am trying to map into intensity plot. I used the example because real vi is big and also need separate driver for the operation. However, the output from the sensor is similar (1D array) which I need to arrange according to what I've described before.
I can not change the way data is coming. I am almost there, just the arrangement problem. Will you please give me some suggestion on how to reverse every other row without flipping the whole array?
04-03-2015 02:06 PM - edited 04-03-2015 02:06 PM
If I understand you correctly, you want to reverse the order of every other row within your 2-D array.
If that is a correct statement, here is the solution to a previous forum post that should be helpful:
http://forums.ni.com/t5/LabVIEW/reverse-2d-array/td-p/1464806
