If you believe that your code requires stacked a sequence structures, you need some more of the LabVIEW tutorials. It has even been removed from the palettes because the use is obsolete and not recommended.
Use a proper state machine. Reduce the size of each screen so you can see the entirety without scrolling. If all that you understand is Express VIs, your program is deeply flawed in all probability.
