Plotting XY Graph for two 1-D Arrays
While plotting XY graph of two 1-D arrays A & B, an unwanted straight line is also displayed which goes from 0 to end of the curve.(As shown in attached pic)
How to get rid of it?
I want only the curve not the unwanted straight line.
Anybody please help.
Regards
(2,797 Views)
Accepted by topic author Waqar123
Hi Waqar,
This description is wrong: that line goes from the end of your curve to (0, 0)!
So the easy solution is to remove the trailing zeros in your A&B arrays…
(2,790 Views)
Can you post your data? My guess is that your arrays have a (0,0) point at the end that you should get rid of.
EDIT: Gerd is too fast 🙂
(2,787 Views)
Thanks.
(2,781 Views)
Yes i had trailing zeros. It worked.
Thanks GerdW & Taki1999
(2,759 Views)
